소개
Use this guide to remove the PCB circuit board in your Xiaomi Redmi 2 for repair or replacement.
필요한 것
Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
Thanks Rodrigo, saved me!
Rodrigo -
Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
Carefully lift the PCB circuit board from the screen assembly and set aside.
The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 3개
my phone is head phone signal
I want purches PCB Circuit not available in Akola service center
That's unnecessary. The cover itself has a small notch on it to remove it to the left
Mad Max - 답글
