주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Xiaomi Redmi 7A 수리는 자사의 서비스 설명서를 사용하세요.
  1. Xiaomi Redmi 7A Teardown, Power off the mobile: 1 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Power off the mobile: 1 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Power off the mobile: 1 단계, 이미지 3개 중 3개
    • This is an easy to forget step, but very important. Please don't skip this step.
    • Start by pressing the power button for 5 seconds.
    • Click on shutdown after the menu appears. Then click the button again.
  2. Xiaomi Redmi 7A Teardown, Remove the back cover: 2 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Remove the back cover: 2 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Remove the back cover: 2 단계, 이미지 3개 중 3개
    • Insert your Opener Pick (or your finger nail) into the gap.
    • Slide the pick (or your finger nail) through the whole perimeter of the phone until all the clips are uncliped.
    • Don't forget to remove the Sim slot!
  3. Xiaomi Redmi 7A Teardown, Removing the top panel: 3 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Removing the top panel: 3 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Removing the top panel: 3 단계, 이미지 3개 중 3개
    • Remove the eight screws on the top panel.
    • Now the top panel will be loose, just pull it out with a little bit of force.
  4. Xiaomi Redmi 7A Teardown, Disconnect the battery: 4 단계, 이미지 2개 중 1개 Xiaomi Redmi 7A Teardown, Disconnect the battery: 4 단계, 이미지 2개 중 2개
    • Put your finger nail under the battery connector.
    • With a little bit of force, push it upwards. It should detach from the Main board's connected.
    • Never use anything that is metallic for this as it can cause damage to the Main board or in the worst case, the battery may explode.
  5. Xiaomi Redmi 7A Teardown, Remove the bottom panel: 5 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Remove the bottom panel: 5 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Remove the bottom panel: 5 단계, 이미지 3개 중 3개
    • Remove the eight screws on the bottom panel.
    • Now the bottom panel, like the top panel, should easily come out with a little bit of force.
  6. Xiaomi Redmi 7A Teardown, Remove the bridge connection: 6 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Remove the bridge connection: 6 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Remove the bridge connection: 6 단계, 이미지 3개 중 3개
    • Remove the connector the same Way we removed the battery connector.
  7. Xiaomi Redmi 7A Teardown, Remove the CC (Charge Connector) board: 7 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Remove the CC (Charge Connector) board: 7 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Remove the CC (Charge Connector) board: 7 단계, 이미지 3개 중 3개
    • Detach the LCD touch cable
    • Detach the Antena cable
    • Remove the entire CC board
  8. Xiaomi Redmi 7A Teardown, Remove the Main board: 8 단계, 이미지 3개 중 1개 Xiaomi Redmi 7A Teardown, Remove the Main board: 8 단계, 이미지 3개 중 2개 Xiaomi Redmi 7A Teardown, Remove the Main board: 8 단계, 이미지 3개 중 3개
    • Remove the screw behind the head phone jack and all the flex cables still attached to the Main board.
    • The board should easily come out now
    • Remove the antenna connected to the board
  9. Xiaomi Redmi 7A Teardown, Remove the front camera: 9 단계, 이미지 2개 중 1개 Xiaomi Redmi 7A Teardown, Remove the front camera: 9 단계, 이미지 2개 중 2개
    • With your fingers, hold and pull out the camera.
  10. Xiaomi Redmi 7A Teardown, Remove the battery: 10 단계, 이미지 1개 중 1개
    • Never use metallic or sharp tools near the battery.
    • With the opener pick, remove the battery and we are done!
    • Follow the steps in reverse to reassemble the phone!
작성자
2다른 기여자 명과 함께
Electronics Boy
회원 가입일: 06/09/22
563 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 27
지난 30일: 81
전체 시간: 3,322
