주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note 3 Disassembly Guide
필요한 것
  1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: 1 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: 1 단계, 이미지 2개 중 2개
    • Locate the sim card tray at the right side of the phone
    • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
  2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: 2 단계, 이미지 1개 중 1개
    • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
  3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: 3 단계, 이미지 1개 중 1개
    • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
  4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: 4 단계, 이미지 1개 중 1개
    • Pull the black tab at the top left of the battery to disconnect the battery from the system
  5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Wedge the tweezers under the battery to lift it up
    • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
    • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
  6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: 6 단계, 이미지 1개 중 1개
    • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
  7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: 7 단계, 이미지 1개 중 1개
    • Remove the loud speaker cover using the tweezers to expose the daughterboard
  8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: 8 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: 8 단계, 이미지 2개 중 2개
    • Remove the two gold tabs on the two top corners of the daughterboard
    • Pry the daughterboard open with the tweezers or pull it out using your fingers
    • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
  9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: 9 단계, 이미지 1개 중 1개
    • Unscrew the four screws at the top of the motherboard and pop up the top cover
    • One screw might by disguised by a sticker so locate that and remove the sticker as well
    • Pulling the top cover without removing all the screws might damage the motherboard
  10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: 10 단계, 이미지 1개 중 1개
    • Remove the rubber cover that’s containing the camera
  11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: 11 단계, 이미지 1개 중 1개
    • Pull the tab that’s holding the front camera to remove the camera protector
    • To keep the camera from damage hold the camera from the corner and not from the middle of it
  12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: 12 단계, 이미지 1개 중 1개
    • Pull out the front camera using tweezers or your fingers
  13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: 13 단계, 이미지 1개 중 1개
    • Remove the five connectors of the motherboard using tweezers or your fingers
  14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: 14 단계, 이미지 1개 중 1개
    • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
  15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: 15 단계, 이미지 1개 중 1개
    • Congrats -- You disassembled the Xiaomi Redmi Note 3!
결론
작성자
5다른 기여자 명과 함께
Meaghan Owens
회원 가입일: 06/23/23
241 평판
안내서 1개를 작성함
1가이드 댓글
Memory ic problem
Sure - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 65
전체 시간: 1,841
