주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first) The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first) The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first)
    • The first thing we have to do is use a pry tool to remove the back cover (make sure to remove the sim tray first)
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off. Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off. Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off.
    • Now we have to remove the battery, luckily the Battery can be removed first after taking the back cover off.
  4. Now you can insert your new battery, pop the back cover on, and your good to go! Congratulations, you've just replaced your phone's battery. Now you can insert your new battery, pop the back cover on, and your good to go! Congratulations, you've just replaced your phone's battery.
    • Now you can insert your new battery, pop the back cover on, and your good to go! Congratulations, you've just replaced your phone's battery.
결론
Congratulations on repairing your smartphone!
다른 한 분이 해당 안내서를 완성하였습니다.
Isaiah Kochis
회원 가입일: 2020년 09월 02일
1 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 43
전체 시간: 105
