소개
If you got a broken Redmi Note 4X LCD, please follow this video to fix the display. It's not difficult to finish the procedure.
필요한 것
동영상 지침
거의 끝나갑니다!
결론
다른 13명이 해당 안내서를 완성하였습니다.
댓글 8개
Hi, Eric.
Thank you for your instructions. Apart from having a broken screen, the gyro sensor is not working. Will this issue be resolved if I change the broken screen, or is the problem much more complicated.
Thank you for your help.
Marcela
marcela - 답글
Hey Marcela, changing the screen wont fix your giroscope, which i think is soldered to the motherboard and will not be easy to fix by yourself
Miguel Trigo -
Very nice good joob
Mustapha el amri - 답글
Hello, thanks for the nice tutorial and link to the shop. I’ve tried purchasing at their place and they seem dead: chat always offline and doesn’t answer. Initiated the refund process on PayPal.
Aubry Moret - 답글
Hi, I'm flavio, and I live in Cambodia. My redmi note 4x has broken the screen. I need some help to find a place we're I can fix my fone
Flávio da Quésede - 답글
The Heat gun is necesary? I dont have one and if i buy one It would be more expensive than sending It to a tech store to repair
juan marquez - 답글
hello, is the screen of xiaomi redmi note 4x snapdragon different from redmi note 4x mediatec
Κωστας Λαζαριδης - 답글
Hello. My front lcd screen popped out. How do I remove the phone from its rear case? I can’t use suction cup as it’ll only pull off the popped out lcd screen. The rest of the board behind lcd remains in Thebes rear case.
Ancient Sniper - 답글
