주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note Front-Facing Camera Replacement
필요한 것
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Front-Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Front-Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 4 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 4 단계, 이미지 2개 중 2개
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Redmi Note Front-Facing Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 1개 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 2개 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Caitlin Settles
회원 가입일: 04/26/17
786 평판
안내서 2개를 작성함
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G4
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 1,753
