주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show how to replace the headphone jack. This guide requires soldering and desoldering the part.
  1. Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Run the plastic opening tool along the seam on the side of the phone to remove the rear casing. Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Locate the indentation at the bottom of the battery. Place a finger in the indentation and lift up to remove the battery.
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Remove twelve 3.5mm Phillips #00 screws from the midframe. Remove twelve 3.5mm Phillips #00 screws from the midframe.
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Insert a plastic opening into the seam between the midframe and the bottom frame of the phone. Run the plastic opening tool along the seam.
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position. Use tweezers to pull the ribbon cable out of the ZIF connector. Remove the front-facing camera from the motherboard.
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left. Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Locate the three ZIF connectors on the motherboard.
    • Locate the three ZIF connectors on the motherboard.
  9. Use tweezers to lift the retaining flap on the ZIF connector to the upright position. Pull the ribbon cable out of the connector by pulling to the left. Repeat these steps for the other two ZIF connectors.
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard. Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard. Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Remove the two 2.9mm Philips #00 screws. Remove the two 2.9mm Philips #00 screws.
    • Remove the two 2.9mm Philips #00 screws.
  12. Flip over the motherboard to reveal the back. Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard. Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Lift up the motherboard and turn it over to place it by the side of the phone. Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Use tweezers to peel the vibrating motor off the frame of the phone. The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it. The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
  15. Flip over the motherboard and locate the headphone jack at the top  left corner. Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
    • Flip over the motherboard and locate the headphone jack at the top left corner.
    • Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
    • Learn how to solder and desolder here.
  16. Use tweezers to pull off the headphone jack from the motherboard.
    • Use tweezers to pull off the headphone jack from the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Zongyi Li
회원 가입일: 2017년 04월 26일
1,335 평판
안내서 3개 작성하였습니다
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G4
4 회원들
안내서 16개 작성하였습니다
You have mentioned it in detailed, but can you mentioned the actual way or sequence of soldering six legs of the jack?
Can you mention the part number of redmi note headphone jack?
link where the jack will be available.
Hemant Kshirsagar - 답글
I want to buy head phone jack, where the jack will
manu tm manu - 답글
You can visit iSparehub.com
iSparehub. Com -
Hey, hast du eine Ahnung, wo man eine Kopfhörerbuchse als Ersatzteil für ein Xiaomi Redmi Note 5 Global herbekommt? Das wäre klasse.
Mathias Bork - 답글
Redmi note 4 earphone jack replacement Ka price Kya hai
Rinku Poonia - 답글
What is the price of audio jackpin of mi note4 sir
nani palavalasa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 28
30일 전: 142
전체 시간: 34,430
