주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note Midframe Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Xiaomi Redmi Note Midframe Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Midframe Replacement: 2 단계, 이미지 1/2 Xiaomi Redmi Note Midframe Replacement: 2 단계, 이미지 2/2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Midframe Replacement: 3 단계, 이미지 1/2 Xiaomi Redmi Note Midframe Replacement: 3 단계, 이미지 2/2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Midframe Replacement, Midframe: 4 단계, 이미지 1/2 Xiaomi Redmi Note Midframe Replacement, Midframe: 4 단계, 이미지 2/2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Midframe Replacement: 5 단계, 이미지 1/2 Xiaomi Redmi Note Midframe Replacement: 5 단계, 이미지 2/2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
결론
Zongyi Li
회원 가입일: 04/26/17
1,560 평판
안내서 3개 작성하였습니다
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G4
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 35
