주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note Motherboard Replacement
필요한 것
  1. Xiaomi Redmi Note Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Motherboard Replacement: 2 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement: 2 단계, 이미지 2/2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Motherboard Replacement: 3 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement: 3 단계, 이미지 2/2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Motherboard Replacement, Midframe: 4 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement, Midframe: 4 단계, 이미지 2/2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Motherboard Replacement: 5 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement: 5 단계, 이미지 2/2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: 6 단계, 이미지 1/3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: 6 단계, 이미지 2/3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Xiaomi Redmi Note Motherboard Replacement, Rear Camera: 7 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement, Rear Camera: 7 단계, 이미지 2/2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Xiaomi Redmi Note Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Locate the three ZIF connectors on the motherboard.
  9. Xiaomi Redmi Note Motherboard Replacement: 9 단계, 이미지 1/3 Xiaomi Redmi Note Motherboard Replacement: 9 단계, 이미지 2/3 Xiaomi Redmi Note Motherboard Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Xiaomi Redmi Note Motherboard Replacement: 10 단계, 이미지 1/3 Xiaomi Redmi Note Motherboard Replacement: 10 단계, 이미지 2/3 Xiaomi Redmi Note Motherboard Replacement: 10 단계, 이미지 3/3
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Xiaomi Redmi Note Motherboard Replacement: 11 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the two 2.9mm Philips #00 screws.
  12. Xiaomi Redmi Note Motherboard Replacement: 12 단계, 이미지 1/3 Xiaomi Redmi Note Motherboard Replacement: 12 단계, 이미지 2/3 Xiaomi Redmi Note Motherboard Replacement: 12 단계, 이미지 3/3
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Xiaomi Redmi Note Motherboard Replacement: 13 단계, 이미지 1/2 Xiaomi Redmi Note Motherboard Replacement: 13 단계, 이미지 2/2
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Xiaomi Redmi Note Motherboard Replacement: 14 단계, 이미지 1/3 Xiaomi Redmi Note Motherboard Replacement: 14 단계, 이미지 2/3 Xiaomi Redmi Note Motherboard Replacement: 14 단계, 이미지 3/3
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
결론
다른 15명이 해당 안내서를 완성하였습니다.
AJ Beers
회원 가입일: 04/26/17
213 평판
안내서 2개 작성하였습니다
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G4
4 회원들
안내서 16개 작성하였습니다
댓글 5개
Good explanation, but the question is : Where to get Xiaomi replacement motherboards ?
Adriano Fonseca - 답글
can we shift bords memory to other bord
krishna - 답글
No we can't get motherboard's memory if it is damaged
sai teja -
Besten Dank an alle für Die Mühe, die sie sich jeweils geben um verständliche Anleitungen zu erstellen,
Oigres Ailgevar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 20
30일 전: 102
전체 시간: 24,917
