주요 콘텐츠로 건너뛰기
Xiaomi Yi Microphone Replacement
필요한 것
  1. Xiaomi Yi Microphone Replacement, Battery: 1 단계, 이미지 2개 중 1개 Xiaomi Yi Microphone Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Microphone Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Yi Microphone Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Yi Microphone Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Microphone Replacement, Front Panel: 3 단계, 이미지 2개 중 1개 Xiaomi Yi Microphone Replacement, Front Panel: 3 단계, 이미지 2개 중 2개
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Microphone Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Yi Microphone Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Yi Microphone Replacement: 4 단계, 이미지 3개 중 3개
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
  5. Xiaomi Yi Microphone Replacement, Back Panel: 5 단계, 이미지 2개 중 1개 Xiaomi Yi Microphone Replacement, Back Panel: 5 단계, 이미지 2개 중 2개
    • Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
  6. Xiaomi Yi Microphone Replacement: 6 단계, 이미지 3개 중 1개 Xiaomi Yi Microphone Replacement: 6 단계, 이미지 3개 중 2개 Xiaomi Yi Microphone Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pull on and remove the black spacer located at the top inside of the camera body using the tweezers and set the part aside.
  7. Xiaomi Yi Microphone Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Yi Microphone Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard from from the back case by gently pulling on the lens housing.
    • Back panel remains.
  8. Xiaomi Yi Microphone Replacement, Microphone: 8 단계, 이미지 2개 중 1개 Xiaomi Yi Microphone Replacement, Microphone: 8 단계, 이미지 2개 중 2개
    • Locate the solder points connected to the red and black wire on the back of the motherboard.
  9. Xiaomi Yi Microphone Replacement: 9 단계, 이미지 1개 중 1개
    • Heat these two points with a Soldering Iron and remove the microphone. Reapply fresh solder with the replacement microphone.
    • Soldering Irons are very hot and fumes from melted solder can cause irritation. Use only in a clean, well ventilated area.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Matt Bibby
회원 가입일: 08/26/15
531 평판
안내서 1개를 작성함
USF Tampa, Team 15-5, Blackwell Fall 2015 USF Tampa, Team 15-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
My camera came with the microphone not soldered at all (two microphone wires were hanging above the motherboard with no sign of soldering).
That was an easy repair as soon as I figured out what's the culprit, but before I've blamed the software for this issue for two days and tinkered with the software for at least 6 hours with no result.
adryjanowski, very nice tutorial, thank you!
Ivan Elizarov - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 8,201
