주요 콘텐츠로 건너뛰기
XtremeMac Luna Dissasembly
필요한 것
  1. XtremeMac Luna Dissasembly, Bottom Panel: 1 단계, 이미지 1/3 XtremeMac Luna Dissasembly, Bottom Panel: 1 단계, 이미지 2/3 XtremeMac Luna Dissasembly, Bottom Panel: 1 단계, 이미지 3/3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dissasembly: 2 단계, 이미지 1/1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dissasembly: 3 단계, 이미지 1/2 XtremeMac Luna Dissasembly: 3 단계, 이미지 2/2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
결론
Daniel Johnson
회원 가입일: 04/14/13
1 평판
안내서 1개 작성함
Cal Poly, Team 3-47, Amido Spring 2013 Cal Poly, Team 3-47, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G47
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 12
전체 시간: 421
