소개
If your iPod won't connect to the Luna while docked, the dock may be faulty. Follow this guide to replace the dock circuit board.
필요한 것
Flip the device over so that the batteries are closest to you.
Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
Push the battery against the spring and lift it out of the casing.
Repeat with the other battery.
Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
거의 끝나갑니다!
결론
