주요 콘텐츠로 건너뛰기
YT-88 Automatic Intelligent Sweeping Robot Full Disassembly
필요한 것
  1. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: 1 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: 1 단계, 이미지 2개 중 2개
    • Turn the robot vacuum upside down to access the screws underneath.
  2. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 2 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 2 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: 2 단계, 이미지 3개 중 3개
    • Using a Phillips 1 screw bit - remove the battery cover and carefully unplug the 18650 rechargeable cell from connector and place it in a safe separate environment along with the battery cover.
  3. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 3 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 3 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: 3 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screw bit remove the screws from both of the sweepers and using a slight force or using the shaft of the driver for leverage, remove the sweepers.
  4. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: 4 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 driver, remove 6 screws from the base of the vacuum and carefully remove the top cover.
  5. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 5 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 5 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: 5 단계, 이미지 3개 중 3개
    • With the top cover now removed we can remove the clipping lid holding the dust box inside which can also be lifted out and removed.
  6. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 6 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 6 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: 6 단계, 이미지 3개 중 3개
    • With the dust box removed we can open the latching lid and remove the dust filter by lifting it up from the provided tabs.
  7. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing drive belts: 7 단계, 이미지 1개 중 1개
    • Back in the internals of the vacuum all located in the bottom cover, the sweeper's drive belts can be then removed easily as they have slack - use the shaft of the screw driver if there are difficulties removing them.
  8. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 8 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 8 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: 8 단계, 이미지 3개 중 3개
    • Carefully using your fingers, the a flat head screwdriver or recommended tweezers, remove the three JST connectors from the PCB which connect the impeller, drive motor assembly and UV light bar.
  9. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: 9 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: 9 단계, 이미지 2개 중 2개
    • With the PCB now disconnected from the components, the PCB can be removed with a Phillips #1 driver. Put this carefully to one side.
    • Keep in mind the battery connecter needs to be fed through the battery compartment as it is soldered to the board.
  10. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: 10 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: 10 단계, 이미지 2개 중 2개
    • Using a Phillips #1 driver remove two screws that are holding the impeller assembly to the chassis - you can lift the assembly from the posts.
  11. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: 11 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: 11 단계, 이미지 2개 중 2개
    • There are two parts that are loose as they used to be held in by the covers being together.
    • The exhaust cover and fake sensor bar can be lifted up and placed aside.
  12. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 12 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 12 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: 12 단계, 이미지 3개 중 3개
    • Using a Phillips #1 driver remove two screws that are holding the UV light bar in place keep this aside.
  13. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 13 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 13 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: 13 단계, 이미지 3개 중 3개
    • Using a Phillips #1 driver remove two screws holding the latched cover in place which will reveal the wheels attached to a shaft. You will need to use some tweezers or a flat head driver to carefully release the clips.
  14. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 14 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 14 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: 14 단계, 이미지 3개 중 3개
    • Using a Phillips #1 driver remove 4 screws holding the driver motor assembly in place - lift this up and keep it aside.
  15. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: 15 단계, 이미지 2개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: 15 단계, 이미지 2개 중 2개
    • Using a Phillips #1 driver, remove two screws securing the rubber seal that creates a tight seal with the floor for the suction. This can be easily removed from it's location.
  16. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 16 단계, 이미지 3개 중 1개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 16 단계, 이미지 3개 중 2개 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: 16 단계, 이미지 3개 중 3개
    • The Impeller assembly can be teared down even further for access such as maintenance or cleaning.
    • There are a few plastic clips that need to be carefully unlatched - use a flat head driver or a shim to do this. Take extra caution as some clips might be brittle and will snap with excessive force.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Frankie Pang
회원 가입일: 10/24/24
253 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 196
