주요 콘텐츠로 건너뛰기
Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt
필요한 것
  1. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 1 단계, 이미지 1/2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Rear Casing: 1 단계, 이미지 2/2
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 2 단계, 이미지 1/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 2 단계, 이미지 2/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 2 단계, 이미지 3/3
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 3 단계, 이미지 1/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 3 단계, 이미지 2/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 3 단계, 이미지 3/3
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 4 단계, 이미지 1/2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 4 단계, 이미지 2/2
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
  5. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 5 단계, 이미지 1/2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Wiring: 5 단계, 이미지 2/2
    • Use the metal spudger to bend down the metal tabs that hold the wires to the terminals. The tabs are small and in between the grooves of the terminal.
  6. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 6 단계, 이미지 1/2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 6 단계, 이미지 2/2
    • Remove the wires from the terminals.
  7. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 7 단계, 이미지 1/2 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 7 단계, 이미지 2/2
    • Use the metal spudger to bend the metal tabs that hold the connectors to the terminals.
  8. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 8 단계, 이미지 1/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 8 단계, 이미지 2/3 Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt: 8 단계, 이미지 3/3
    • Remove the wires from the terminals. Then remove the entire wire assembly.
  9. Yamaha NS-AW190BL Front Panel and Speaker Housing Replacepemt, Front Panel and Speaker Housing: 9 단계, 이미지 1/1
    • Once the wire assembly is removed, the entire front panel and speaker housing should be separated to replace.
결론
Nick Ruiz
회원 가입일: 02/07/17
331 평판
안내서 3개 작성하였습니다
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 21
전체 시간: 1,511
