소개
This guide will walk you through the process of replacing the input/output panel.
필요한 것
Remove all four .5 mm Phillips head screws located on the back panel of the device.
Pull out the input/output panel from the back of the device once all four screws are removed.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
