주요 콘텐츠로 건너뛰기
Yamaha NS-AW190BL Rear Casing Replacement
필요한 것
  1. Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: 1 단계, 이미지 1/2 Yamaha NS-AW190BL Rear Casing Replacement, Rear Casing: 1 단계, 이미지 2/2
    • Remove the six Phillips Head 1.2mm screws on the front side of the speaker.
  2. Yamaha NS-AW190BL Rear Casing Replacement: 2 단계, 이미지 1/3 Yamaha NS-AW190BL Rear Casing Replacement: 2 단계, 이미지 2/3 Yamaha NS-AW190BL Rear Casing Replacement: 2 단계, 이미지 3/3
    • Crack open both parts of the casing carefully.
    • Using a plastic opening tool, wedge open the bottom of the speaker to separate the two parts of the speaker.
  3. Yamaha NS-AW190BL Rear Casing Replacement: 3 단계, 이미지 1/3 Yamaha NS-AW190BL Rear Casing Replacement: 3 단계, 이미지 2/3 Yamaha NS-AW190BL Rear Casing Replacement: 3 단계, 이미지 3/3
    • Remove the cooling foam.
    • Use a metal spudger to push the tab in on the red wire.
    • Repeat the process for the blue wire.
  4. Yamaha NS-AW190BL Rear Casing Replacement: 4 단계, 이미지 1/2 Yamaha NS-AW190BL Rear Casing Replacement: 4 단계, 이미지 2/2
    • The blue wire can now be removed from its connector.
    • Remove the red wire to free the rear casing.
결론
Nick Ruiz
회원 가입일: 02/07/17
331 평판
안내서 3개 작성하였습니다
USF Tampa, Team 17-3, Blackwell Spring 2017 USF Tampa, Team 17-3, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 826
