소개
This guide will assist in the installation of the keyboard's batteries. This is essential in performing most of the other repair guides.
  1. Turn the keyboard over so that the keys are facing the ground.
    • Turn the keyboard over so that the keys are facing the ground.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Pop the tabs on the battery casing and remove it from the back plate.
    • Pop the tabs on the battery casing and remove it from the back plate.
  4. Locate the six batteries and remove them from the battery cavity.
    • Locate the six batteries and remove them from the battery cavity.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin Green
회원 가입일: 2012년 09월 18일
246 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G62
2 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 54
전체 시간: 2,531
