주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yamaha YPG-225 Display Replacement
필요한 것
  1. Yamaha YPG-225 Display Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Display Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Display Replacement, Faceplate: 4 단계, 이미지 1개 중 1개
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Display Replacement: 7 단계, 이미지 1개 중 1개
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Display Replacement: 8 단계, 이미지 2개 중 1개 Yamaha YPG-225 Display Replacement: 8 단계, 이미지 2개 중 2개
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Display Replacement, Main Circuit Board: 9 단계, 이미지 1개 중 1개
    • Locate the main circuit board in the middle of the detached face plate.
  10. Yamaha YPG-225 Display Replacement: 10 단계, 이미지 2개 중 1개 Yamaha YPG-225 Display Replacement: 10 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or spudger to carefully pry up the beige ribbon connectors and remove the wires from them.
    • Be sure to use a tool that is ESD safe!
    • Use a slightly upward force as parallel to the ground as possible.
    • Be sure to make a mental note or jot down the locations of the specific ribbon cables. Some are in close proximity to each other and it can be easy to forget which ribbon goes where.
    • Be sure to unplug the smaller ribbon that connects to a different circuit board.
    • Take care not to use too much force. The connectors are fragile, the ribbon wires are easily bent, and too much force may damage the circuit board if you happen to miss.
  11. Yamaha YPG-225 Display Replacement: 11 단계, 이미지 1개 중 1개
    • Move the ribbons out of the way, and remove the eight 10mm screws in the middle that hold the circuit board down.
    • Remove the two 12mm screws in the corner of the circuit board.
  12. Yamaha YPG-225 Display Replacement: 12 단계, 이미지 1개 중 1개
    • Remove this wire carefully by hand.
  13. Yamaha YPG-225 Display Replacement: 13 단계, 이미지 1개 중 1개
    • Completely remove the circuit board from the face plate.
  14. Yamaha YPG-225 Display Replacement, Display: 14 단계, 이미지 1개 중 1개
    • Slide out the screen from its case on the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Lonnie Bissmeyer
회원 가입일: 09/16/12
468 평판
안내서 4개를 작성함
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G62
2 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 51
전체 시간: 4,275
