주요 콘텐츠로 건너뛰기
Yamaha YPG-225 Keys Replacement
필요한 것
  1. Yamaha YPG-225 Keys Replacement, Batteries: 1 단계, 이미지 1/1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: 2 단계, 이미지 1/1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: 3 단계, 이미지 1/1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Keys Replacement, Faceplate: 4 단계, 이미지 1/1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: 5 단계, 이미지 1/1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: 6 단계, 이미지 1/1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: 7 단계, 이미지 1/1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: 8 단계, 이미지 1/2 Yamaha YPG-225 Keys Replacement: 8 단계, 이미지 2/2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: 9 단계, 이미지 1/1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: 10 단계, 이미지 1/1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: 11 단계, 이미지 1/2 Yamaha YPG-225 Keys Replacement: 11 단계, 이미지 2/2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: 12 단계, 이미지 1/1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kevin Green
회원 가입일: 09/18/12
308 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G62
2 회원들
안내서 6개 작성하였습니다
댓글 3개
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - 답글
Great article. Thank you so much.
Andreas Devig - 답글
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 21,161
