주요 콘텐츠로 건너뛰기
Yamaha YZF-R6 Fan Relay Replacement
필요한 것
  1. Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: 1 단계, 이미지 1/3 Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: 1 단계, 이미지 2/3 Yamaha YZF-R6 Fan Relay Replacement, Yamaha YZF-R6 Fan Relay: 1 단계, 이미지 3/3
    • Use your motorcycle's key to open the rear seat, and remove the seat to access the tool pouch.
  2. Yamaha YZF-R6 Fan Relay Replacement: 2 단계, 이미지 1/2 Yamaha YZF-R6 Fan Relay Replacement: 2 단계, 이미지 2/2
    • Use a 10 mm Allen key to remove the front seat and expose the battery.
  3. Yamaha YZF-R6 Fan Relay Replacement: 3 단계, 이미지 1/2 Yamaha YZF-R6 Fan Relay Replacement: 3 단계, 이미지 2/2
    • Using a Phillips-head screwdriver, remove the screws attached to the battery terminals.
  4. Yamaha YZF-R6 Fan Relay Replacement: 4 단계, 이미지 1/3 Yamaha YZF-R6 Fan Relay Replacement: 4 단계, 이미지 2/3 Yamaha YZF-R6 Fan Relay Replacement: 4 단계, 이미지 3/3
    • Using the 10mm Allen key, remove the hardware securing the left side fairings.
  5. Yamaha YZF-R6 Fan Relay Replacement: 5 단계, 이미지 1/3 Yamaha YZF-R6 Fan Relay Replacement: 5 단계, 이미지 2/3 Yamaha YZF-R6 Fan Relay Replacement: 5 단계, 이미지 3/3
    • Remove the middle fairing on the left-hand side, and carefully unclip the turn signal cable.
  6. Yamaha YZF-R6 Fan Relay Replacement: 6 단계, 이미지 1/3 Yamaha YZF-R6 Fan Relay Replacement: 6 단계, 이미지 2/3 Yamaha YZF-R6 Fan Relay Replacement: 6 단계, 이미지 3/3
    • Once you have removed the left-hand cover under the clutch lever, locate the relay assemblies for the lights and cooling fans.
  7. Yamaha YZF-R6 Fan Relay Replacement: 7 단계, 이미지 1/2 Yamaha YZF-R6 Fan Relay Replacement: 7 단계, 이미지 2/2
    • Use a flat-head screwdriver to gently pry the locking mechanism open on the relay assembly. You can remove the relay by itself or with the bracket assembly.
결론
Jose Perez 323
회원 가입일: 10/23/23
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 5-18, Kershman Fall 2023 CSU Los Angeles, Team 5-18, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G18
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 32
전체 시간: 313
