주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Yobo Gameware Controller Trigger Spring Replacement
필요한 것
  1. Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Be sure the controller is disconnected from the console or any source of power.
    • Place the controller (button - side down) on a clean, solid work surface.
    • Use your screwdriver to remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    댓글 쓰기
  2. Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 2 단계, 이미지 2개 중 1개 Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 2 단계, 이미지 2개 중 2개
    • Gently life the back panel up, separating it from the front panel.
    • Some components could fall off the front panel if the controller is knocked around during this step.
    댓글 쓰기
  3. Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 3 단계, 이미지 3개 중 1개 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 3 단계, 이미지 3개 중 2개 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 3 단계, 이미지 3개 중 3개
    • Depress the trigger assembly using your index finger while using your thumb to keep upward pressure on the grey square bracket and clear circular component on the underside of the trigger assembly.
    • Maintain a firm grip on the entire assembly, as the components could spring apart if you release pressure.
    • Rotate the assembly upwards and towards you to remove it from its housing in the controller.
    • The removal process is the same for both the left and right triggers.
    댓글 쓰기
  4. Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 4 단계, 이미지 2개 중 1개 Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 4 단계, 이미지 2개 중 2개
    • Gently release pressure on the trigger assembly, allowing the components to come apart on your work surface.
    • A new spring may now be incorporated into the designated trigger assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Shoaf
회원 가입일: 04/12/22
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 70
전체 시간: 931
