주요 콘텐츠로 건너뛰기
Yoga Tab 3 Pro Rear Panel Replacement
필요한 것
  1. Yoga Tab 3 Pro Rear Panel Replacement, Preparation: 1 단계, 이미지 1/3 Yoga Tab 3 Pro Rear Panel Replacement, Preparation: 1 단계, 이미지 2/3 Yoga Tab 3 Pro Rear Panel Replacement, Preparation: 1 단계, 이미지 3/3
    • Flip the tablet with the rear panel facing up.
    • Push the central button to lift the support.
    • Open the support entirely, using your hands.
    • Remember to turn off the device before doing any repair.
  2. Yoga Tab 3 Pro Rear Panel Replacement, Unscrew the rear shell: 2 단계, 이미지 1/3 Yoga Tab 3 Pro Rear Panel Replacement, Unscrew the rear shell: 2 단계, 이미지 2/3 Yoga Tab 3 Pro Rear Panel Replacement, Unscrew the rear shell: 2 단계, 이미지 3/3
    • You'll need to remove the adesive on the back plate before removing the screws.
    • Remove the sticker using the plastic spudger by lifting it up from one side, then you can remove it entirely by using your fingers.
    • Use the Philips #0 screwriver to remove the three screws.
  3. Yoga Tab 3 Pro Rear Panel Replacement, Separate the two halfs: 3 단계, 이미지 1/3 Yoga Tab 3 Pro Rear Panel Replacement, Separate the two halfs: 3 단계, 이미지 2/3 Yoga Tab 3 Pro Rear Panel Replacement, Separate the two halfs: 3 단계, 이미지 3/3
    • Divide the two halfs by inserting the spudger in the gap between the front shell and the rear one. To help you out with this job you can also use some guitar picks.
    • Do the same procedure on all three visible sides, including the two round side parts.
    • Be careful not to insert the spudger too deep into the device, to not damage the internal component.
    • You could use a little bit of force since the half is also hooked in the central portion on the tablet.
    • Important: the rear shell is the one that you remove from the front one; the internal component including the display, will stay attached to the front panel.
  4. Yoga Tab 3 Pro Rear Panel Replacement, Separation: 4 단계, 이미지 1/3 Yoga Tab 3 Pro Rear Panel Replacement, Separation: 4 단계, 이미지 2/3 Yoga Tab 3 Pro Rear Panel Replacement, Separation: 4 단계, 이미지 3/3
    • Once you unhook all the internal clips you can easily remove the rear panel.
    • Watch out at the two side keys and at the central one, since they'll detach form the rear shell. and You'll need to put them back during the reassembly.
결론
To reassemble the device, folllow these instruction in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
Domenyck Paoly님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
jacopo
회원 가입일: 03/25/14
4,382 평판
안내서 3개 작성하였습니다
JappoTech JappoTech 회원
Business
1 회원
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 255
