주요 콘텐츠로 건너뛰기
Yujin Robot iCLEBO Arte Dust Bin Replacement
필요한 것
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: 1 단계, 이미지 1개 중 1개
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: 2 단계, 이미지 2개 중 1개 Yujin Robot iCLEBO Arte Dust Bin Replacement: 2 단계, 이미지 2개 중 2개
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
결론
To reassemble the dust bin, follow these instructions in reverse order.
작성자
2다른 기여자 명과 함께
Trent Treiber
회원 가입일: 02/28/17
204 평판
안내서 2개를 작성함
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 회원
USFT-NANCE-S17S2G3
4 회원들
안내서 14개를 작성함
3가이드 댓글
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - 답글
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
Amy Abbiatti - 답글
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 1,272
