주요 콘텐츠로 건너뛰기
Yujin Robot iCLEBO Arte Main Brush Replacement
필요한 것
  1. Yujin Robot iCLEBO Arte Main Brush Replacement, Dust Bin: 1 단계, 이미지 1개 중 1개
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Main Brush Replacement: 2 단계, 이미지 2개 중 1개 Yujin Robot iCLEBO Arte Main Brush Replacement: 2 단계, 이미지 2개 중 2개
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 3 단계, 이미지 3개 중 1개 Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 3 단계, 이미지 3개 중 2개 Yujin Robot iCLEBO Arte Main Brush Replacement, Main Brush: 3 단계, 이미지 3개 중 3개
    • Flip over the device to access the brush cover.
    • To remove the brush cover, push together the two snap releases on the right and left sides of the cover until it releases.
    • Do not push the release snaps too close together. Doing so may cause them to break and the brush could fall out when in use.
  4. Yujin Robot iCLEBO Arte Main Brush Replacement: 4 단계, 이미지 2개 중 1개 Yujin Robot iCLEBO Arte Main Brush Replacement: 4 단계, 이미지 2개 중 2개
    • Grip the left side of the brush with the square end-piece and pull up until the brush pops out.
  5. Yujin Robot iCLEBO Arte Main Brush Replacement: 5 단계, 이미지 3개 중 1개 Yujin Robot iCLEBO Arte Main Brush Replacement: 5 단계, 이미지 3개 중 2개 Yujin Robot iCLEBO Arte Main Brush Replacement: 5 단계, 이미지 3개 중 3개
    • When preparing a new brush, it is very important to make sure that the new one is equipped with the proper end-pieces.
    • Take the round metal piece and slide it into the square rubber coating. Then, stick it on the end with the metal peg.
결론
작성자
3다른 기여자 명과 함께
Trent Treiber
회원 가입일: 02/28/17
204 평판
안내서 2개를 작성함
USF Tampa, Team S2-G3, Nance Spring 2017 USF Tampa, Team S2-G3, Nance Spring 2017 회원
USFT-NANCE-S17S2G3
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 1,138
