소개
If you own a Yuneec ST10 Plus, there is a chance your battery will stop holding its charging capacity over time. The main causes of this issue are battery overheating, and the end of your battery charge/discharge cycles. Follow this step-by-step guide on how to replace your battery. No tools required and a quick replacement.
Flip the controller upside down to access the battery compartment.
Grab the compartment door and pull down.
다른 2명이 해당 안내서를 완성하였습니다.
