주요 콘텐츠로 건너뛰기
Yuneec ST10 Plus Screen Replacement
필요한 것
  1. Yuneec ST10 Plus Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the controller upside down to access the battery compartment.
    • Grab the compartment door and pull down.
  2. Yuneec ST10 Plus Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
  3. Yuneec ST10 Plus Screen Replacement: 3 단계, 이미지 3개 중 1개 Yuneec ST10 Plus Screen Replacement: 3 단계, 이미지 3개 중 2개 Yuneec ST10 Plus Screen Replacement: 3 단계, 이미지 3개 중 3개
    • To disconnect the battery from the remote, grab the red and black connectors.
    • Pull gently on connectors until they disconnect.
  4. Yuneec ST10 Plus Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 Yuneec ST10 Plus Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
    • Slide the Jimmy underneath the rubber grips and pry upwards.
    • With your free hand grasp the rubber grips and pull upward to remove it.
  5. Yuneec ST10 Plus Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the six 1.3 cm screws located on the back panel of the remote using the 5.5mm hex screw bit.
  6. Yuneec ST10 Plus Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 6mm screws from the handle using the 4mm hex driver bit.
  7. Yuneec ST10 Plus Screen Replacement: 7 단계, 이미지 2개 중 1개 Yuneec ST10 Plus Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull up and over on the back panel to remove. Take your time because there are wires connecting the two panels that can easily be torn.
  8. Yuneec ST10 Plus Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Take a Phillips #0 screwdriver to unscrew the three 5mm screws on the screen circuit board.
  9. Yuneec ST10 Plus Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Take the flat end of the spudger and place it under the white lock on the ribbon cable's ZIF connector. Then lift it up on the white lock to allow the ribbon cable to be removed.
  10. Yuneec ST10 Plus Screen Replacement: 10 단계, 이미지 2개 중 1개 Yuneec ST10 Plus Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pry up the black tape on the center ribbon connector
    • On the ribbon connector is a black lock located on top of the connector closest to the ribbon.
    • To unlock, use the spudger's pointed end to place under the lock and lift up.
    • Remove the ribbon cable.
  11. Yuneec ST10 Plus Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully disconnect the two wires connected underneath the screen motherboard with the plastic spudger.
  12. Yuneec ST10 Plus Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screw driver, remove the four 6mm screws holding the screen fan plate on.
  13. Yuneec ST10 Plus Screen Replacement: 13 단계, 이미지 2개 중 1개 Yuneec ST10 Plus Screen Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, disconnect your screen connection wires.
  14. Yuneec ST10 Plus Screen Replacement: 14 단계, 이미지 2개 중 1개 Yuneec ST10 Plus Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Using too much force will destroy screen plate.
    • There is a location on the upper right hand corner, where you can use the spudger to gently pry the screen up.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Joshua Collins
회원 가입일: 01/27/20
586 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 335
