주요 콘텐츠로 건너뛰기
Yuneec ST16S Cooling Fan Replacement
필요한 것
  1. Yuneec ST16S Cooling Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Hold down the button located above the battery while applying downward pressure to the battery.
  2. Yuneec ST16S Cooling Fan Replacement: 2 단계, 이미지 1/2 Yuneec ST16S Cooling Fan Replacement: 2 단계, 이미지 2/2
    • While still holding down the button, slide the battery out of its slot.
  3. Yuneec ST16S Cooling Fan Replacement, Backplate: 3 단계, 이미지 1/1
    • Remove the single screw from the battery compartment.
  4. Yuneec ST16S Cooling Fan Replacement: 4 단계, 이미지 1/2 Yuneec ST16S Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Remove the rubber bumpers from the back of the device using a spudger.
  5. Yuneec ST16S Cooling Fan Replacement: 5 단계, 이미지 1/2 Yuneec ST16S Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Remove the two screws located under each of the rubber bumpers.
  6. Yuneec ST16S Cooling Fan Replacement: 6 단계, 이미지 1/3 Yuneec ST16S Cooling Fan Replacement: 6 단계, 이미지 2/3 Yuneec ST16S Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Remove the three screws along the top of the device.
  7. Yuneec ST16S Cooling Fan Replacement: 7 단계, 이미지 1/2 Yuneec ST16S Cooling Fan Replacement: 7 단계, 이미지 2/2
    • Carefully remove the backplate from the device.
  8. Yuneec ST16S Cooling Fan Replacement, Cooling Fan: 8 단계, 이미지 1/2 Yuneec ST16S Cooling Fan Replacement, Cooling Fan: 8 단계, 이미지 2/2
    • Remove the screws from the metal bracket and around the cooling fan.
  9. Yuneec ST16S Cooling Fan Replacement: 9 단계, 이미지 1/1
    • Unplug the cooling fan from the device.
  10. Yuneec ST16S Cooling Fan Replacement: 10 단계, 이미지 1/1
    • Remove the cooling fan from the device.
결론
Christian Resendes
회원 가입일: 10/28/21
589 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 56
