주요 콘텐츠로 건너뛰기
Yuneec Typhoon H Gimbal Bushing Reattachment
필요한 것
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: 1 단계, 이미지 1/2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: 1 단계, 이미지 2/2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: 2 단계, 이미지 1/3 Yuneec Typhoon H Gimbal Bushing Reattachment: 2 단계, 이미지 2/3 Yuneec Typhoon H Gimbal Bushing Reattachment: 2 단계, 이미지 3/3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
결론
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
다른 2명이 해당 안내서를 완성하였습니다.
Jake Breul
회원 가입일: 04/16/18
127 평판
안내서 1개 작성함
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 회원
CPSU-MANESS-S18S22G3
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Camera not getting power after crash.
Don - 답글
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - 답글
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,616
