주요 콘텐츠로 건너뛰기
Yuneec Typhoon H Landing Gear Replacement
필요한 것
  1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: 1 단계, 이미지 1/2 Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: 1 단계, 이미지 2/2
    • Lift all drone arms up so you can access the landing gear easily.
  2. Yuneec Typhoon H Landing Gear  Replacement: 2 단계, 이미지 1/3 Yuneec Typhoon H Landing Gear  Replacement: 2 단계, 이미지 2/3 Yuneec Typhoon H Landing Gear  Replacement: 2 단계, 이미지 3/3
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  3. Yuneec Typhoon H Landing Gear  Replacement: 3 단계, 이미지 1/1
    • Pull the landing leg out slowly and remove it from the device.
결론
Your Yuneec Typhoon H should now be ready to fly safely again.
다른 한 분이 해당 안내서를 완성하였습니다.
Shasta Banchio
회원 가입일: 04/16/18
130 평판
안내서 1개 작성함
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 회원
CPSU-MANESS-S18S22G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 977
