주요 콘텐츠로 건너뛰기
Yuneec Typhoon H Plus Propeller Replacement
  1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: 1 단계, 이미지 1/1
    • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
    • An A-propeller will have a black button in the center and an A imprinted on the propeller.
    • A B-propeller will have a white button and a B imprinted on the propeller.
    • Though the A and B propellers are different the steps to replace one are the same.
  2. Yuneec Typhoon H Plus Propeller Replacement: 2 단계, 이미지 1/1
    • Press down on the button firmly.
  3. Yuneec Typhoon H Plus Propeller Replacement: 3 단계, 이미지 1/2 Yuneec Typhoon H Plus Propeller Replacement: 3 단계, 이미지 2/2
    • Hold the base of the propeller with your pointer finger.
    • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
    • Lift the propeller off the drone.
결론
Brice Black
회원 가입일: 01/23/20
557 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G1, White Winter 2020 Cal Poly, Team S2-G1, White Winter 2020 회원
CPSU-WHITE-W20S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 182
