주요 콘텐츠로 건너뛰기
Yuneec Typhoon H Slip Ring Yaw Motor Replacement
필요한 것
  1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement, Slip Ring Yaw Motor: 1 단계, 이미지 1/1
    • Remove the Motor Battery Component from the Drone.
  2. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 2 단계, 이미지 1/2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 2 단계, 이미지 2/2
    • Prop the top cover of the motor piece off the Motor Battery Component. Using Phillips #00 screwdriver, unscrew the three screws (their lengths are 5.9 mm) that are in this top cover piece. This will remove the battery from the top piece.
  3. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 3 단계, 이미지 1/1
    • Grabbing the Motor Piece, remove the bottom cap of this motor piece. The cap should pop right off.
  4. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 4 단계, 이미지 1/1
    • Using the Philips #000 screwdriver, unscrew the two 5.9 mm screws and remove the retaining clip on top of the motor piece.
  5. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 5 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove the four 6.3 mm motor mount screws on top of the motor piece.
  6. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 6 단계, 이미지 1/1
    • Once these screws are removed, pop off the top of the motor piece.
  7. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 7 단계, 이미지 1/2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 7 단계, 이미지 2/2
    • Using the Phillips #000 screwdriver, remove the two 4.9 mm screws on the side of the plastic cover holding the wires together.
    • Once these screws are removed, press down on this plastic cover to reveal the wires. Pull the locking tabs that are on the end of this piece to completely remove this plastic cover.
  8. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 8 단계, 이미지 1/2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 8 단계, 이미지 2/2
    • Pull out the white wire connecter that is currently in the wire assembly.
  9. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the white wire connector cap using the tweezers. This is for the wires that are currently in the motor piece. Do take note of the orientation and order of the wires.
  10. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 10 단계, 이미지 1/2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: 10 단계, 이미지 2/2
    • Removed the damaged slip ring motor by guiding the wires through the opening in the motor piece. Use a pair of pliers to make sure the wires are pushed through the opening in the center of the motor piece.
결론
To reassemble your device, follow these instructions in reverse order (This process is in the guide steps for reference).
다른 3명이 해당 안내서를 완성하였습니다.
Davis Ross
회원 가입일: 04/16/18
321 평판
안내서 1개 작성함
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 회원
CPSU-MANESS-S18S22G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Ive done all the above but digging out the epoxy it took almost all wire with it i couldve solderd to so what to do now its the white wire by the way the camera still stabalises and points straight just cant manually control
donkymeet - 답글
The White or Green wire is most likely not making connection
YuneecSkins.com -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,320
