주요 콘텐츠로 건너뛰기
ZCWA BR151 Battery Replacement
필요한 것
  1. ZCWA BR151 Battery Replacement, Water Tank: 1 단계, 이미지 1/1
    • Turn off the device.
  2. ZCWA BR151 Battery Replacement: 2 단계, 이미지 1/2 ZCWA BR151 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Battery Replacement, Battery: 3 단계, 이미지 1/2 ZCWA BR151 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Flip the device over to access the panels on the back.
    • Rotate the device to where the battery panel is closest to you.
    • Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
  4. ZCWA BR151 Battery Replacement: 4 단계, 이미지 1/2 ZCWA BR151 Battery Replacement: 4 단계, 이미지 2/2
    • From the opposite end of the battery wires, use an opening tool to pry the battery out.
    • Do not use metal objects to pry out the battery.
    • You may need to rotate the device depending on your hand prominence.
  5. ZCWA BR151 Battery Replacement: 5 단계, 이미지 1/1
    • Peel off the electrical tape that wraps around the battery's wire connectors.
  6. ZCWA BR151 Battery Replacement: 6 단계, 이미지 1/2 ZCWA BR151 Battery Replacement: 6 단계, 이미지 2/2
    • Pinch the two lock mechanisms on the wire connectors while pulling them apart.
    • Set aside the old battery to dispose of later.
    • Batteries can be safely disposed of at your local recycling center with the help of a professional.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kaitlyn Baltz
회원 가입일: 01/22/24
419 평판
안내서 3개 작성하였습니다
Tennessee Tech University, Team 1-1, Pickering Spring 2024 Tennessee Tech University, Team 1-1, Pickering Spring 2024 회원
TNTECH-PICKERING-S24S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Ok cool I hope it works
Blueobear - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 44
전체 시간: 153
