주요 콘텐츠로 건너뛰기
ZCWA BR151 Velcro Replacement
필요한 것
  1. ZCWA BR151 Velcro Replacement, Velcro: 1 단계, 이미지 1/2 ZCWA BR151 Velcro Replacement, Velcro: 1 단계, 이미지 2/2
    • Turn off the device.
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  2. ZCWA BR151 Velcro Replacement: 2 단계, 이미지 1/1
    • Use a Jimmy to get underneath the velcro until you are able to push it up enough to grab.
  3. ZCWA BR151 Velcro Replacement: 3 단계, 이미지 1/1
    • Use tweezers to peel off the rest of the velcro.
    • If necessary, use the spudger to remove more of the adhesive beneath the velcro.
    • You will need four velcro strips. Cut out two, 1-inch long strips of velcro.
    • Cut an additional two, 3-inch long strips.
    • If your velcro strips already have an adhesive back, simply attach them to the top of the mop bracket.
    • If you are using a hot glue gun to attach your velcro, place a small section of glue where you want the velcro to go, then carefully press your piece down.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Claire Harris
회원 가입일: 01/16/24
151 평판
안내서 1개 작성함
Tennessee Tech University, Team 1-1, Pickering Spring 2024 Tennessee Tech University, Team 1-1, Pickering Spring 2024 회원
TNTECH-PICKERING-S24S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 54
