주요 콘텐츠로 건너뛰기
ZCWA BR151 Water Filter Replacement
필요한 것
  1. ZCWA BR151 Water Filter Replacement, Water Tank: 1 단계, 이미지 1/1
    • Turn off the device.
  2. ZCWA BR151 Water Filter Replacement: 2 단계, 이미지 1/2 ZCWA BR151 Water Filter Replacement: 2 단계, 이미지 2/2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Water Filter Replacement, Water Filter: 3 단계, 이미지 1/3 ZCWA BR151 Water Filter Replacement, Water Filter: 3 단계, 이미지 2/3 ZCWA BR151 Water Filter Replacement, Water Filter: 3 단계, 이미지 3/3
    • Remove the filter holders, on the bottom of the water tank, one at a time by maneuvering the spudger under the flaps of the filter holders.
    • Use the spudger to lift enough of the flap up to pinch it between two fingers.
    • Pull the flap up while pinching it to dislodge the filter holder from the water tank.
  4. ZCWA BR151 Water Filter Replacement: 4 단계, 이미지 1/3 ZCWA BR151 Water Filter Replacement: 4 단계, 이미지 2/3 ZCWA BR151 Water Filter Replacement: 4 단계, 이미지 3/3
    • To extract the cotton filters, push the flaps of the filter holders down.
    • Use the tweezers to pull out the filter.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kaitlyn Baltz
회원 가입일: 01/22/24
419 평판
안내서 3개 작성하였습니다
Tennessee Tech University, Team 1-1, Pickering Spring 2024 Tennessee Tech University, Team 1-1, Pickering Spring 2024 회원
TNTECH-PICKERING-S24S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 16
전체 시간: 48
