주요 콘텐츠로 건너뛰기
ZCWA BR151 Wheel Replacement
필요한 것
  1. ZCWA BR151 Wheel Replacement, Water Tank: 1 단계, 이미지 1/1
    • Turn off the device.
  2. ZCWA BR151 Wheel Replacement: 2 단계, 이미지 1/2 ZCWA BR151 Wheel Replacement: 2 단계, 이미지 2/2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Wheel Replacement, Wheel: 3 단계, 이미지 1/2 ZCWA BR151 Wheel Replacement, Wheel: 3 단계, 이미지 2/2
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  4. ZCWA BR151 Wheel Replacement: 4 단계, 이미지 1/1
    • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
    • Remove the bumper guards by lifting them.
  5. ZCWA BR151 Wheel Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
  6. ZCWA BR151 Wheel Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
  7. ZCWA BR151 Wheel Replacement: 7 단계, 이미지 1/2 ZCWA BR151 Wheel Replacement: 7 단계, 이미지 2/2
    • Carefully lift the bottom panel off of the top.
    • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
    • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
  8. ZCWA BR151 Wheel Replacement: 8 단계, 이미지 1/1
    • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
    • Pinch the wire bracket that is on the top panel while pulling the bracket away.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  9. ZCWA BR151 Wheel Replacement: 9 단계, 이미지 1/3 ZCWA BR151 Wheel Replacement: 9 단계, 이미지 2/3 ZCWA BR151 Wheel Replacement: 9 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the single screw to the spring.
    • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
  10. ZCWA BR151 Wheel Replacement: 10 단계, 이미지 1/2 ZCWA BR151 Wheel Replacement: 10 단계, 이미지 2/2
    • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
    • Pinch the silver brackets and pull the wire casing away from the motherboard.
    • Remove the wheel from the vacuum.
    • Repeat Steps 6-10 to replace the wheel on the opposite side.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gavin H. Stackhouse
회원 가입일: 01/31/24
351 평판
안내서 2개 작성하였습니다
Tennessee Tech University, Team 1-1, Pickering Spring 2024 Tennessee Tech University, Team 1-1, Pickering Spring 2024 회원
TNTECH-PICKERING-S24S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 98
