주요 콘텐츠로 건너뛰기
ZD-N Plus Wireless Controller Left Joystick Replacement
필요한 것
  1. ZD-N Plus Wireless Controller Left Joystick Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Left Joystick Replacement: 2 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement: 2 단계, 이미지 2개 중 2개
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Left Joystick Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Left Joystick Replacement: 4 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement: 4 단계, 이미지 2개 중 2개
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Left Joystick Replacement: 5 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Left Joystick Replacement, Rumble Motor: 6 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement, Rumble Motor: 6 단계, 이미지 2개 중 2개
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller Left Joystick Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller Left Joystick Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller Left Joystick Replacement, Left Joystick: 9 단계, 이미지 2개 중 1개 ZD-N Plus Wireless Controller Left Joystick Replacement, Left Joystick: 9 단계, 이미지 2개 중 2개
    • Pull up on the left joystick to remove it from the motherboard. The plastic piece will unclip easily.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stacie Schmidt
회원 가입일: 10/15/19
433 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 922
