주요 콘텐츠로 건너뛰기
ZTE Avail 2 Battery Replacement
  1. ZTE Avail 2 Battery Replacement, Battery: 1 단계, 이미지 1/3 ZTE Avail 2 Battery Replacement, Battery: 1 단계, 이미지 2/3 ZTE Avail 2 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Battery Replacement: 2 단계, 이미지 1/2 ZTE Avail 2 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the battery by the notch in the back plate.
    • Once you have removed the battery replace it with the new one.
    • Carefully insert the new battery with the connectors aligned correctly.
    • Gently push down on the battery until it clicks into place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Samantha Smith
회원 가입일: 09/21/15
309 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-6, Sydow campbell Fall 2015 University of Alabama, Team 1-6, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G6
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 524
