소개
Use this guide to replace your perishing battery.
After successfully removing the battery, and putting a new battery in, your device should now power on properly.
Remove the back cover using the notch at the bottom of the device.
Pull the back cover from the front panel gently to remove it.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
