주요 콘텐츠로 건너뛰기
ZTE Avail 2 Camera Replacement
필요한 것
  1. ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 1/3 ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 2/3 ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 3/3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: 2 단계, 이미지 1/2 ZTE Avail 2 Camera Replacement: 2 단계, 이미지 2/2
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: 3 단계, 이미지 1/1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: 4 단계, 이미지 1/2 ZTE Avail 2 Camera Replacement: 4 단계, 이미지 2/2
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: 5 단계, 이미지 1/2 ZTE Avail 2 Camera Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: 6 단계, 이미지 1/1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: 7 단계, 이미지 1/2 ZTE Avail 2 Camera Replacement: 7 단계, 이미지 2/2
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: 8 단계, 이미지 1/3 ZTE Avail 2 Camera Replacement: 8 단계, 이미지 2/3 ZTE Avail 2 Camera Replacement: 8 단계, 이미지 3/3
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
결론
다른 5명이 해당 안내서를 완성하였습니다.
haugaustin
회원 가입일: 09/22/15
355 평판
안내서 1개 작성함
University of Alabama, Team 1-6, Sydow campbell Fall 2015 University of Alabama, Team 1-6, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G6
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 461
