주요 콘텐츠로 건너뛰기
ZTE Avail 2 Camera Replacement
필요한 것
  1. ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 ZTE Avail 2 Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: 2 단계, 이미지 2개 중 1개 ZTE Avail 2 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: 3 단계, 이미지 1개 중 1개
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: 4 단계, 이미지 2개 중 1개 ZTE Avail 2 Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: 5 단계, 이미지 2개 중 1개 ZTE Avail 2 Camera Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: 7 단계, 이미지 2개 중 1개 ZTE Avail 2 Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: 8 단계, 이미지 3개 중 1개 ZTE Avail 2 Camera Replacement: 8 단계, 이미지 3개 중 2개 ZTE Avail 2 Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
haugaustin
회원 가입일: 09/22/15
355 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 614
