소개
Caution! Ribbons should NOT be torn when disassembling the motherboard from the phone! Use tweezers to GENTLY wiggle the ribbons back and forth to loosen and separate ribbons from the motherboard and phone.
필요한 것
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Use the tweezers to remove the four ribbon wires on the sides of the device.
다른 5명이 해당 안내서를 완성하였습니다.
