소개
This is a total breakdown of the phone, and requires you to dissemble the parts pictured in order to access the screen.
필요한 것
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Use the tweezers to remove the four ribbon wires on the sides of the device.
Carefully pry the screen away from the motherboard.
Remove the remaining two ribbon wires from their connectors.
Wedge the plastic spudger between the screen and the digitizer.
Gently pry apart the screen from the digitizer.
Wrong instructions wound up breaking the frame thanks sooooooo much you don't need to remove the ribbons if you do you wind up breaking them and from there on I have no idea what the !&&* is going on
I just replaced the screen on my AWE with this guide. There are 3 ribbon cables to remove,
you have to open a flap to remove cable ( google it , if your not sure )
The reason you remove motherboard is for the ribbon cable on the screen , it passes under
neath.
Pry the screen as shown all around the phone, its glued on. Be careful you dont go too far
under ( I scratched the digitizer underneath )
Not that hard, just go slow. Fixed for 10 dollars vs 60 for new one.
I don't understand how does that replace the broken screen?
다른 12명이 해당 안내서를 완성하였습니다.
