주요 콘텐츠로 건너뛰기
ZTE Blade E Battery Replacement
필요한 것
  1. ZTE Blade E Battery Replacement, Removing the cover: 1 단계, 이미지 1/1
    • Take a spudger and remove the back panel.
  2. ZTE Blade E Battery Replacement, Removal: 2 단계, 이미지 1/1
    • Carefully remove the battery with a spudger.
  3. ZTE Blade E Battery Replacement, New battery: 3 단계, 이미지 1/1
    • Take the new battery and place it into the slot. The phone should operate normally.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Alan Toussaint
회원 가입일: 10/08/14
588 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-5, Leahy Fall 2014 USF Tampa, Team 9-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G5
3 회원들
안내서 10개 작성하였습니다
댓글 2개
[http://Please help me fix my phone|I can’t tell what is wrong with my phone it won’t turn on I've had it on the charger for days!!!!!]
AHL DeRoche - 답글
where can I buy a replacement battery, model # Li3816T43P4h604550 For ZTE Blade
memeandmim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 9,909
