주요 콘텐츠로 건너뛰기
ZTE Blade E Front Panel Replacement
필요한 것
  1. ZTE Blade E Front Panel Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Using a spudger, remove the back panel of the phone.
  2. ZTE Blade E Front Panel Replacement: 2 단계, 이미지 2개 중 1개 ZTE Blade E Front Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery and SD card from the phone.
  3. ZTE Blade E Front Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
  4. ZTE Blade E Front Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back piece, exposing the motherboard.
  5. ZTE Blade E Front Panel Replacement: 5 단계, 이미지 3개 중 1개 ZTE Blade E Front Panel Replacement: 5 단계, 이미지 3개 중 2개 ZTE Blade E Front Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Flip up the three small tan clips holding the ribbons in place.
  6. ZTE Blade E Front Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Gently slide each of the three ribbons out of the motherboard.
  7. ZTE Blade E Front Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Slide the motherboard off of the ribbons detaching it from the front of the phone.
  8. ZTE Blade E Front Panel Replacement, Front Panel: 8 단계, 이미지 1개 중 1개
    • Carefully use the spudger to free the screen from the front panel. You can use your hands to pull it the rest of the way out once you have freed the screen from the clips.
  9. ZTE Blade E Front Panel Replacement: 9 단계, 이미지 1개 중 1개
    • Dispose of the old font panel and replace it with the new one.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lilia Johnson
회원 가입일: 10/08/14
799 평판
안내서 2개를 작성함
USF Tampa, Team 9-5, Leahy Fall 2014 USF Tampa, Team 9-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
I have the blade max .It's not even a month old and it won't charge it won't turn on ot is a crap Ola phone .So I take it bk to cricket ,well they can replace it ,I have to send it off wait a few days and they return me my phone.Why in the name of creation can't your stores replace them .Why did I pay good money to send it bk and be without a phone for several days,why because your a crappy company and I need my phone..
Laura Henderson - 답글
Matter a fact this is my second non functioning ZTE phone. Crap Ola phone..
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 6,084
