주요 콘텐츠로 건너뛰기
ZTE Blade E Motherboard Replacement
필요한 것
  1. ZTE Blade E Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Using a spudger, remove the back panel of the phone.
  2. ZTE Blade E Motherboard Replacement: 2 단계, 이미지 1/2 ZTE Blade E Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery and SD card from the phone.
  3. ZTE Blade E Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the five 4mm Philips #00 screws, circled in red, holding the the back down.
  4. ZTE Blade E Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the back piece, exposing the motherboard.
  5. ZTE Blade E Motherboard Replacement: 5 단계, 이미지 1/3 ZTE Blade E Motherboard Replacement: 5 단계, 이미지 2/3 ZTE Blade E Motherboard Replacement: 5 단계, 이미지 3/3
    • Flip up the three small tan clips holding the ribbons in place.
  6. ZTE Blade E Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently slide each of the three ribbons out of the motherboard.
  7. ZTE Blade E Motherboard Replacement: 7 단계, 이미지 1/1
    • Slide the motherboard off of the ribbons detaching it from the front of the phone.
    Excelente gráfica,gran aporte
    Juan - 답글
    I have a ZTE Blade C370 in the workshop to change the LCD, I would like to be able to contribute some material. There is a tutorial where I can see what I need to be able to contribute. For example, the quality of the images and their descriptions.
    Alvaro Gomes - 답글
결론
다른 9명이 해당 안내서를 완성하였습니다.
Lilia Johnson
회원 가입일: 10/08/14
790 평판
안내서 2개 작성하였습니다
USF Tampa, Team 9-5, Leahy Fall 2014 USF Tampa, Team 9-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G5
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Zte blade a506 insert sim card problem
Ali Jaffar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 4,082
