주요 콘텐츠로 건너뛰기
ZTE Blade E Volume Button Replacement
필요한 것
  1. ZTE Blade E Volume Button Replacement, Remove back panel from phone: 1 단계, 이미지 1개 중 1개
    • Using your finger nails or a spudger, remove the back panel from the phone.
  2. ZTE Blade E Volume Button Replacement, Remove battery and microSD card: 2 단계, 이미지 2개 중 1개 ZTE Blade E Volume Button Replacement, Remove battery and microSD card: 2 단계, 이미지 2개 중 2개
    • Using your fingernails or a spudger, remove the phones battery and microSD card.
  3. ZTE Blade E Volume Button Replacement, Remove back panel screws: 3 단계, 이미지 1개 중 1개
    • Remove the five 4mm Phillip's #00 screws, circled in red, from the back panel.
  4. ZTE Blade E Volume Button Replacement, Separate back panel from motherboard: 4 단계, 이미지 1개 중 1개
    • Separate the back panel from the motherboard.
  5. ZTE Blade E Volume Button Replacement, Remove volume button: 5 단계, 이미지 3개 중 1개 ZTE Blade E Volume Button Replacement, Remove volume button: 5 단계, 이미지 3개 중 2개 ZTE Blade E Volume Button Replacement, Remove volume button: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, remove the volume button by unlatching the two white bands holding it in place.
  6. ZTE Blade E Volume Button Replacement, Replace volume button: 6 단계, 이미지 2개 중 1개 ZTE Blade E Volume Button Replacement, Replace volume button: 6 단계, 이미지 2개 중 2개
    • Either replace the volume button with a new one, or reinsert the old one using a pair of tweezers. It should look like the pictures when inserted properly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sean Gardner
회원 가입일: 10/08/14
369 평판
안내서 1개를 작성함
USF Tampa, Team 9-5, Leahy Fall 2014 USF Tampa, Team 9-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
Ok my ZTE has gone insane it does whatever whenever it wants. Freezes, jumps around, locks, want download from play, home button don't work, plays music from unknown place. Went bought another just like it. A week and apparently it's contagious bc now other new phone is doing weird stuff volume button don't work sometimes freezes jumps and unfreeze, keyboard goes away and comes back
mirlace4 - 답글
cont..i posted bc iwas afraid it would eat mess. Serious here IDK what to do about to go outside and shoot both of them getting them out of there mystery
mirlace4 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 2,070
