주요 콘텐츠로 건너뛰기
ZTE Blade X Max Midframe Replacement
필요한 것
  1. ZTE Blade X Max Midframe Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 ZTE Blade X Max Midframe Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Midframe Replacement: 2 단계, 이미지 3개 중 1개 ZTE Blade X Max Midframe Replacement: 2 단계, 이미지 3개 중 2개 ZTE Blade X Max Midframe Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Midframe Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Midframe Replacement: 4 단계, 이미지 3개 중 1개 ZTE Blade X Max Midframe Replacement: 4 단계, 이미지 3개 중 2개 ZTE Blade X Max Midframe Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Midframe Replacement: 5 단계, 이미지 3개 중 1개 ZTE Blade X Max Midframe Replacement: 5 단계, 이미지 3개 중 2개 ZTE Blade X Max Midframe Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Midframe Replacement: 6 단계, 이미지 2개 중 1개 ZTE Blade X Max Midframe Replacement: 6 단계, 이미지 2개 중 2개
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Midframe Replacement, Midframe: 7 단계, 이미지 1개 중 1개
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Midframe Replacement: 8 단계, 이미지 3개 중 1개 ZTE Blade X Max Midframe Replacement: 8 단계, 이미지 3개 중 2개 ZTE Blade X Max Midframe Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Midframe Replacement: 9 단계, 이미지 3개 중 1개 ZTE Blade X Max Midframe Replacement: 9 단계, 이미지 3개 중 2개 ZTE Blade X Max Midframe Replacement: 9 단계, 이미지 3개 중 3개
    • Use the Jimmy to remove the midframe from the device.
결론
작성자
4다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
100,293 평판
안내서 258개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,774개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 284
