주요 콘텐츠로 건너뛰기
ZTE Blade Z Max Fingerprint Sensor Replacement
필요한 것
  1. ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: 1 단계, 이미지 1/3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: 1 단계, 이미지 2/3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: 1 단계, 이미지 3/3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Fingerprint Sensor Replacement: 2 단계, 이미지 1/3 ZTE Blade Z Max Fingerprint Sensor Replacement: 2 단계, 이미지 2/3 ZTE Blade Z Max Fingerprint Sensor Replacement: 2 단계, 이미지 3/3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Fingerprint Sensor Replacement, Fingerprint Sensor: 3 단계, 이미지 1/1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Fingerprint Sensor Replacement: 4 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 4 단계, 이미지 2/2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Fingerprint Sensor Replacement: 5 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 5 단계, 이미지 2/2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Fingerprint Sensor Replacement: 6 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 6 단계, 이미지 2/2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Fingerprint Sensor Replacement: 7 단계, 이미지 1/1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Fingerprint Sensor Replacement: 8 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 8 단계, 이미지 2/2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Fingerprint Sensor Replacement: 9 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 9 단계, 이미지 2/2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Fingerprint Sensor Replacement: 10 단계, 이미지 1/2 ZTE Blade Z Max Fingerprint Sensor Replacement: 10 단계, 이미지 2/2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ronald Weimar
회원 가입일: 09/24/18
1,438 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 12
전체 시간: 820
