소개
If your battery isn't working. (on this phone it was bloated and about to burst) here is how to fix it! You will need to remove the back plate and disconnect the old battery to replace it.
필요한 것
First, remove the microSD tray, use a sim ejector tool for this.
Begin by removing the upper and lower plastic panels. Pry the top with a spudger from the corners as shown in the red circle.
Remove the SIM card.
Next pry off the lower plastic panel. This one is stuck on a little bit more.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
An additional more comprehensive wiki troubleshooting guide for the ZTE Max …compiled by a team of students here on “IFIXIT” that I recently discovered that you may also find helpful.
