주요 콘텐츠로 건너뛰기
ZTE Compel Speaker Replacement
필요한 것
  1. ZTE Compel Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
  4. ZTE Compel Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 1개 ZTE Compel Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 2개
    • Remove the 9 screws that measure 4 mm Phillips. Use your PH000 screwdriver attachment.
    • Use your iFixit Magnetic Project Mat to hold your removed screws while working on your ZTE Compel
  5. ZTE Compel Speaker Replacement: 5 단계, 이미지 3개 중 1개 ZTE Compel Speaker Replacement: 5 단계, 이미지 3개 중 2개 ZTE Compel Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the flat end of your black plastic spudger into the crease and work it around the entire circumference of the phone until the front and back are separated.
  6. ZTE Compel Speaker Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The speaker is located in the top-left corner of the back plate. Using your tweezers, grip the sides of the speaker and pull it out.
    • Be cautious pulling the speaker out as it might move while pulling it due to adhesive wearing away.
결론
작성자
3다른 기여자 명과 함께
Tayler McCleese
회원 가입일: 09/06/18
246 평판
안내서 2개를 작성함
Ohio State, Team S1-G4, Whitney Fall 2018 Ohio State, Team S1-G4, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G4
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 245
